INTRO AND STARTING
With so many starts and stops with the Kingfisher and then the weeks of the stress crack repairs, the build spent a lot of time in the repair booth doing nothing but drying as the repairs kept going on and I had basically nothing to do. I knew I wanted the build the Revell Spit Mk lla after following John’s build and would go at it a bit differently. Over the years, I had accumulated a lot of Barracuda resin sets all of which were for the cockpit except one, which was for the exterior upgrades.  Most of the sets were designed as I can see for the Tamiya Spits and with some work would work on the Revell kit. I also had Edgar’s notes and would incorporate a good number of his suggestions.
The game changer for me, was the awesome Quinta cockpit set and I’ve become a huge fan of their products as my last two builds used them: GWH P-40B and the Tamiya Spitfire Mk XVIe. Crisp and clean, easy to use and no hunting around as to where they go. I decided to save the Barracuda sets for other Spitfire builds and just use the exterior upgrade set and leave the interior to the Quinta set.
So while waiting for the Kingfisher to immerge from the repair shop, there was plenty of time to start the Spit. Lots of part clean up and these are the old Revell instructions – so care needs to be exercised. The front office is done and except for some cables that need to be added to the right hand cockpit side wall from under the IP and the shoulder belters for the Sutton harness, the fuselage is almost ready to be glued up.
MRP RAF Interior Green was used for the entire interior – I really like their rendition and for touch up work, I have the MRP matching color from their acrylic range – perfect combination.
Typical Revell and with some work the interior looks good and with the Quinta detail set, it’s close to a wow from a just OK.
 Quinta IP Set
Both the kit joystick was done as well as the Barracuda joystick - not sure which to use. The seat still needs work as well, as I forgot to paint the actual seat the reddish brown Bakelite color - has since been repainted.
  • Like 16
Nice start Peter. The Quinta set really ups the cockpit details. Like you, I have a bunch of the Barracuda resin bits but may have to look closer at the Quinta set.
Thanks Carl
I look at Barracuda resin as 'old school' and showing its age. The Quinta set has all the bells and whistles and no issues adding plus it comes with a nice set of Sutton harnesses and no brush painting required.
16 hours ago, Peterpools said:
INTRO AND STARTING
 Quinta IP Set
Looking good Peter! :)
Thanks Dennis, they are fantastic and well worth the expense. I have a good number now and treat them in the same light as canopy mask sets - a must before starting a build. I'm itching to get going on the Border Lancaster but the Quinta detail set isn't available yet. It is supposed to be released this week and I'm still tossing as to order direct or wait for SB to receive them.
50 minutes ago, Peterpools said:
Thanks John
I'm following your build as it keeps me on the path and more importantly, what to look out for.
I hope it will be of some help in your build! :)
THE FRONT OFFICE
Steady work on the front office and it’s about 95% done. A full Quinta cockpit set was used and it brought the rather plain jane office to a new level. Getting all the parts to fit has been a chore and I’m still at it. The kit’s instructions are the old style and a good number of specific fit details are either not shown or are just too unclear to be of help. I’m still fussing with trying to get everything to line up and it quite doesn't. The other issue is fitting the cockpit assembly into the fuselage half so the left cockpit wall can be added and the fuselage closed up. Just a lot of tweaking and sanding but I’m getting there.
My office has a few 'goofs' but they look fine and when everything is closed up, none can be seen. Hopefully by tonight, the fuselage will be together. One small part that stills needs some TLC is the rear portion of the Sutton harness .. just a bit finicky.
As it seems, I’m getting into WWII RAF aircraft this year and after the Spit, I’m hoping to start the Border Lancaster. I’m waiting for the Quinta Detail set to be released hopefully tomorrow and then have to decide if it’s safe to order it directly from Quinta or wait for Sprue Bros to receive it.
Thanks Mike, very much appreciated. It isn't often I get stoked to keep working so consistently at the bench but I'm on a role and hope to keep the juices flowing at a good clip until at least the main assembly is done.
Peter, the cockpit is looking great. At least you haven't made the mistake of forgetting to install the side panels. Did that on my build. Only found it much later after I was finished.
Thanks Carl, much appreciated.
I did almost the same on a Tamiya F-14, forgetting to install the compressor blades. Nice to know we have all been down that road.:wallbash:
Thanks Dennis. Time marches on and the Quinta set truly brings up the detail and interest level of the kits front office without needing to spend hours sorting through a lot of resin upgrade parts.
The pit looks fantastic, Peter. Quinta sets are great, but it needs a knowing hand to integrate them that well.
Looking Soooo Nice Peter!I have the Quintas for the Revell MkIX why not use our local sponsor HobbyNuts they seem to have more Quintas than SB?:notworthy:
Peter , stunning cockpit. The finishing you achieve is very realistic, one day I might get close……..looked at RedFox and they do not supply the Lanc IP etc yet. Did notice they do the Mosquito so will purchase from them…..
Thanks Rob, just followed the excellent mini-instructions, a set of Tamiya instructions and a few pics and all was well. I find using Micro Krystal Kleer works perfectly, with plenty of time for adjustments and I've been using Quinta decals this from the first time I tried them and never has a single decal fallen off.
