Cees - this is a beautiful build, and it gives me hope to see that there are projects here with even longer lifecycles than my own!
Besides which, watching this evolve is something akin to a master course in conversions.
  • 1 month later...
Been a while but I got some work done on the Mancunian. If you look hard on photographs there is something fitted under the rear canopy. This is a piece of armourglass to protect the flight engineer. In the book Dambuster Lancaster this becomes clearer, see pic.
so this is my representation. I also attempted to make the structure inside the rear canopy which is made from spruce strips on the real Lanc. Unfortunately glue was smeared on the clear plastic. Oh well, back to square one.
I built up the canopy framework on the Tamiya 48th Lancaster so I know of the challenge you are undertaking  . . . . good luck with your progress :respect:
And the antenne has been made, still needs to cut to length. A steel pin serves as anchor and the mast is intended to be fitted after the canopy.
I have a spare. The reason why I cut off the rear section from the first canopy is to have better access. I think making the interior structure is more of a pain in the petoetie than that it's worth. So am thinking about representing the structure with painted strips of thick tape, or just paint over from the outside. The horizontal frames will be sanded off and the frames need to be represented on the inside. Only the boltheads were visible on the outside. We tried to pass that info on to HKM but they didn't take it up.
The canopy masks are on their way. After the canopy and the fuselage windows have been masked of, I think it's time the fuselage gets a primer coat. But I am happy with the progress so far.
Cees
Making the antenna fit the canopy by drilling holes and filing out to shape.
Next to sand away the horizontal frames on the exterior of the rear canopy section.
Cees
Well the second try was not a succes as the clear coat was contaminated and as a sesult the canopy was not very clear.
so here is attemp #3, where the sliding sidewindows have been fitted. Closed in my case. After a thorough clean it will be masked inside and out.
cheers
Cees
