BlrwestSiR Posted November 19, 2018 Author Posted November 19, 2018 On 11/16/2018 at 6:00 PM, harv said: Now how many you have on the bench Carl ??.....harv Too many? But hopefully I'll be getting a couple done soon. 1
BlrwestSiR Posted November 19, 2018 Author Posted November 19, 2018 I made up the lap belts and installed them on the seat. I forgot to take the picture earlier. With the cockpit finally done, I closed up the fuselage. I had to use a tiny bit of filler, mostly in front of the cockpit. Then I joined up the fuselage and wing assemblies. It's starting to look like a Spitfire now. Carl 5
Administrators JeroenPeters Posted November 19, 2018 Administrators Posted November 19, 2018 Sweet! Have this kit in about the same stage. Need to finish it! Love the barrels. And i mean the wooden ones’ 1
Peterpools Posted November 20, 2018 Posted November 20, 2018 Carl Seatbelts and harness look mighty good and looking good all buttoned up. Keep ‘em Peter 1
BlrwestSiR Posted March 20, 2020 Author Posted March 20, 2020 Well, with all my posts in "What's on your Bench?" I thought it best I find and update the actual build thread. First up are the barrels themselves. On the original pair I did, I had sanded off the bands that hold the barrels together. Whoops. Thankfully the barrels came in sets of 4 so I had an extra pair. I gave the barrels a quick stain using a Vallejo wash. They were then airbrushed with Tamiya clear orange. I then masked off and painted the cooper bands in black. 4
BlrwestSiR Posted March 20, 2020 Author Posted March 20, 2020 Turning to the plane, I finished assembling the engine cradle. The Merin was then installed and I finished the kit included plumbing. The power egg was then installed onto the fuselage. I also fitted the fixed sections of the canopy and masked them off. The removable cowl panels were put into place to act as masks for the engine and to get a consistent camo scheme. Working a bit differently this time from an painting perspective, I started with the in stripes. I've generally done these after the camo scheme. After masking off the borders, I started on the camo. I'm using AK Real Colors for this. I should have started with the Ocean Grey as I ended up with some touch ups over the green. For the RAF roundels, I prefer to use masks and airbrush these. The ones I used were a mix of Montex and Maketar ones. Some were used on previous builds but still fine. 5
BlrwestSiR Posted March 20, 2020 Author Posted March 20, 2020 I then used some mixed Tamiya paints for the roundels colours. I then finally painted the undersides and removed the majority of the masking tape on the fuselage. Next up will be finishing the invasion stripes and the fuselage codes. 8
BlrwestSiR Posted March 21, 2020 Author Posted March 21, 2020 So it turns out I either made things really difficult for myself with the fuselage codes or there really was no other way around doing them. First step was to mask things off for the codes. I then sprayed the Sky for these. Then I masked over these and painted the black stripes. Once the black stripes were done, I masked over those and filled in the negative spaces where the base camo showed through. 4
BlrwestSiR Posted March 21, 2020 Author Posted March 21, 2020 Here's where it really got fun. The tail number for JE-J Jr was MK 329. For some reason, Profimodeller made their mask for the tail number MK823. Not sure where they got that one from. So I had to make that into the proper number by taping off individual bits of the mask and getting the correct number. Now all that's left are the wing stripes. 8
Anthony in NZ Posted March 21, 2020 Posted March 21, 2020 That's really nice!!! Love everything about your build! 2 1
BlrwestSiR Posted March 21, 2020 Author Posted March 21, 2020 56 minutes ago, Anthony in NZ said: That's really nice!!! Love everything about your build! Thanks Anthony! I'm glad to finally see this project make some headway. 3
BlrwestSiR Posted March 22, 2020 Author Posted March 22, 2020 A small update. I assembled the lower cowl and intake but didn't get the intake aligned correctly so there's a step in it that would be a bit of a pain to fix. Thankfully I have extra Spitfire parts so I pulled out another cowl and put that one together. The misaligned one is on the left while the new intake is yet to be joined to the cowl. 3
DocRob Posted March 23, 2020 Posted March 23, 2020 Nice paintjob and lots of masking involved. May I ask about the grey camo triangle on the right side of the fuselage. On the left side you have full black stripes and on the right there is mentioned grey triangle. Did they paint the original that inconsistent? Cheers Rob 2 1
BlrwestSiR Posted March 23, 2020 Author Posted March 23, 2020 Thanks Rob! I followed the instructions included with Victory Productions decal sheet which shows the irregular cutouts. I think the Spitfire was painted that way so as to avoid painting over as much of the fuselage codes as possible. 2
BlrwestSiR Posted March 23, 2020 Author Posted March 23, 2020 I masked and painted the wing stripes last night. This just leaves the fin flash left to do. Which I nearly forgot about. 4
shark64 Posted March 23, 2020 Posted March 23, 2020 impressive markings painting. where did u get the metal round template? 2 1
BlrwestSiR Posted March 23, 2020 Author Posted March 23, 2020 10 minutes ago, shark64 said: impressive markings painting. where did u get the metal round template? It's made by Hasegawa. I use it for cutting quick circles but mostly for masking off wheels. The diameters go up in 0.5mm increments which makes it easy to find the right size. https://www.hlj.com/cutting-template-c-hsgtp-7 2
Bomber_County Posted March 23, 2020 Posted March 23, 2020 That’s a lot of masking, me and masks nearly always lift the base and top coats, I clean before priming etc etc.......the spit is look fab....... 1 1
BlrwestSiR Posted March 23, 2020 Author Posted March 23, 2020 9 minutes ago, Bomber_County said: That’s a lot of masking, me and masks nearly always lift the base and top coats, I clean before priming etc etc.......the spit is look fab....... Thanks Phil! Try de-tacking the paint masks first. Some folks will gently apply the mask to their hands or another clean surface first so that the adhesive isn't as strong. I generally don't do that as either the masks are too tiny and potentially fragile or I've repositioned them a couple times which helps reduces their adhesion. Here's my favourite mask that I've used so far: Just need to build the rest of the model to go with it. 4
BlrwestSiR Posted March 30, 2020 Author Posted March 30, 2020 I got lazy and used decals for the fin flash. Worse than lazy, I used the kit decals... Hopefully this doesn't bite me in the butt too much. 6
GusMac Posted March 30, 2020 Posted March 30, 2020 Probably won't be a problem Carl and it saves a lot of cursing. I used masks for the fin flash on my MkXVIe and they were a pain in the ass to get aligned correctly. The 'spare' bit hanging over the front edge stuck to other things, the other side and me!! My wife wasn't impressed by the vocabulary. 5
DocRob Posted April 1, 2020 Posted April 1, 2020 On 3/30/2020 at 4:40 PM, BlrwestSiR said: I got lazy and used decals for the fin flash. Worse than lazy, I used the kit decals... At least, the Colours seem to match, more or less. Cheers Rob 4
BlrwestSiR Posted April 5, 2020 Author Posted April 5, 2020 On 3/30/2020 at 4:22 PM, GusMac said: Probably won't be a problem Carl and it saves a lot of cursing. I used masks for the fin flash on my MkXVIe and they were a pain in the ass to get aligned correctly. The 'spare' bit hanging over the front edge stuck to other things, the other side and me!! My wife wasn't impressed by the vocabulary. That's usually what happens to me as well. On 4/1/2020 at 9:54 AM, DocRob said: At least, the Colours seem to match, more or less. Cheers Rob They are a close enough match thankfully. 4
