EVERYTHING UKRAINE GROUP BUILD IS NOW UNDERWAY.
Martinnfb
 Share
First steps with rust!
Ammo Scratches Effects and faded French Blue over the rusty base colours. Still lots to do with chipping, oils, dry brushing, etc but pretty happy with it as a base to work on. Just the rest of the chassis and bits to go....
21 hours ago, krow113 said:
Weren't those trucks aluminum body panels ...?
Could be Steve, can't find clear answer anywhere but I don't care anyway. Whole point of this build was to try rust techniques and it'll go straight in the display case, so I'm the only one who'll see it. I'm claiming artistic licence... 😁
In the moment there is little time for modelling, therefore I shelved the Arado momentarily, which I wanted to build with full concentration and continued with the Chinese Tankette, which is a much simpler affair.
The primed parts where accentuated and modulated with Nato black.
Then a transparent coat of olive green, which was used pronouncing the darker areas.
Then a lighter mix with some drops of yellow green, followed by an even lighter mix with IJN cockpit green, sprayed on the lighter pars of the mini tank and from above.
I than added the running gear and made a mock up with the prepared tracks, only to see if the vinyl stuff fits. It does and has a really spongy working suspension.
Looks great Rob. I had fun with my build. I now want to try the Japanese version. With
regards to the tracks; mine developed a split on one side after sitting on the shelf for
months. I have been unable to fix the gap.
Thanks a lot, until now, the tracks seem to be pretty robust, but due to the suspension, there is some tension on them. I do not trust the rubber material, but hope for the best.
Looks great, Rob!
On 11/6/2021 at 12:19 AM, Martinnfb said:
Not exactly on my bench, but also a very exciting beginning of an ambitious, international project. And thanks to Hubert, this might even look presentable. :)
 Thank You again my faraway friend.
Martin
Could it be the start of a Sea Fury?
Nice progress on the tankette there Rob.  Not a bad idea to pause on the Arado and do something less involved.
22 minutes ago, Peterpools said:
Martin
I think that's a Cavalier Mustang. Which would be the only reason for me to get another P-51. :sofa:
8 hours ago, Martinnfb said:
Very correct, this is the only reason to get another P-51
Not the nicest of all Mustangs, but interesting, never heard about that one before. Looks a bit like a Frankenstang with the nose of a FW-190 D and you definitely need to drill out the enormous exhaust :D.
BTW: Have I ever mentioned, that I like subject off the trotten pathes.
  Only 75 emoji are allowed.
 Share
