1to1scale Posted April 30, 2019 Posted April 30, 2019 that would be a really hard one to cast in a one piece mold, you might need to lay it flat in a clamshell mold, see below. 3
TJTX Posted April 30, 2019 Author Posted April 30, 2019 On 4/30/2019 at 3:57 PM, 1to1scale said: that would be a really hard one to cast in a one piece mold, you might need to lay it flat in a clamshell mold, see below. Expand Yea, I noticed the resin trapped air and wouldn't flow down. Guess I need to learn how to make a 2 part mold. 3
1to1scale Posted April 30, 2019 Posted April 30, 2019 another way to try is to split the mold in half along the blade edges like the picture above then cut a small channel from the tip to the end, get a large syringe, then inject the resin. from the bottom up. 3
1to1scale Posted April 30, 2019 Posted April 30, 2019 Don't be discouraged, long thin parts are the hardest to cast, pros either inject, or use pressure pots. 5
Administrators Clunkmeister Posted April 30, 2019 Administrators Posted April 30, 2019 Tony, you’re whipping this one into shape. It looks amazing with your normal attention to detail. 4 1
TJTX Posted May 2, 2019 Author Posted May 2, 2019 3rd attempt was better, but FAR from where it needs to be. I'm battling how to set up my mold, this is my 2nd mold I've built. I'm struggling how to get the resin in, and I'm struggling with the blade being flexible instead of solid. It is most definitely very frustrating. 4
Martinnfb Posted May 2, 2019 Posted May 2, 2019 Definitely a progress. I am admiring your persistence and phenomenal ability to evolve as a modeller. Constant improvement of your skills is stunning. Hats off to you Tony. 4
TJTX Posted May 3, 2019 Author Posted May 3, 2019 Thanks guys. I guess I'll need to make a 2 part mold like Mark suggested. 4
Administrators Clunkmeister Posted May 3, 2019 Administrators Posted May 3, 2019 Tony, you’re already light years ahead of my ability with molding. I’ll be coming to you for advice soon enough 3
TJTX Posted May 3, 2019 Author Posted May 3, 2019 Thanks guys. I may take a break from the props for now and continue on the fuselage to get closer to closing it up. I'm busy getting a new type rating in May so the building rate will really slow down but this is my one and only project till it's all wrapped up. I also need to figure out what type of hard points were on the wing for the drop tanks. They're certainly not original Mustang ones. 4
TJTX Posted May 12, 2019 Author Posted May 12, 2019 Worked on the belly air system today. An all white plane makes color decisions relatively easy, but I'm realizing that anything missed will stand out BIG time. My goal is to have the fuselage closed by the end of June. I'd love to have this thing wrapped up for a show in September but I highly doubt it right now. As long as shes ready for San Marcos I'll be happy. 3
Martinnfb Posted May 13, 2019 Posted May 13, 2019 This is very ambitious project Tony and naturally it takes adequate amount of time to reach your goals. No need to rush or explain anything. Once done, she's gonna be beaut Cheers M. 3
HubertB Posted May 13, 2019 Posted May 13, 2019 It looks like you did your mold vertical, from tip of the blade to root of the blade. For a long and thin part like this one, I believe it is probably more efficient to do the mold « horizontal », with a big casting block along the leading or trailing edge. Thus any trapped bubbles have less way to do to escape from the viscous resin. I have also read that having your mix cup high above the mold, to thin down the fillet of resin flowing down into the mold, has the effect of removing some of the bubbles trapped in the mixing process. Hubert 4
TJTX Posted May 15, 2019 Author Posted May 15, 2019 I have a joined fuselage. Always a nice milestone. 7
JohnB Posted May 16, 2019 Posted May 16, 2019 Looks like it's coming right along . I'm considering building that a/c too as it really appeals to me. I have the decals ordered so I'll have to do some research on it. I don't know if you know it but there is a book named "Wet Wings and Drop Tanks" concerning this bird. I just ordered a copy on Amazon. Whenever you get the prop blades sorted out I might want to get a set from you if you don't mind doing that. Keep up the good work!!! 4
Wumm Posted May 17, 2019 Posted May 17, 2019 On 5/13/2019 at 7:26 AM, HubertB said: It looks like you did your mold vertical, from tip of the blade to root of the blade. For a long and thin part like this one, I believe it is probably more efficient to do the mold « horizontal », with a big casting block along the leading or trailing edge. Thus any trapped bubbles have less way to do to escape from the viscous resin. I have also read that having your mix cup high above the mold, to thin down the fillet of resin flowing down into the mold, has the effect of removing some of the bubbles trapped in the mixing process. Hubert Expand Yes I agree, Try casting lengthwise, with the thin edge down, and a long tapered mould stub attached to the thick side to better allow the sanding process after casting. 4 1
TJTX Posted May 17, 2019 Author Posted May 17, 2019 On 5/17/2019 at 12:03 AM, Wumm said: Yes I agree, Try casting lengthwise, with the thin edge down, and a long tapered mould stub attached to the thick side to better allow the sanding process after casting. Expand This is priceless! I couldn't quite picture how to accomplish this but the drawing helps immensely. I've shaped all 4 blades now so I can experiment a little and not be terrified if something goes wrong. 4
Wumm Posted May 17, 2019 Posted May 17, 2019 You're welcome Tony, Once the mould is made, you can use a wedge to spread the slit apart while you pour the resin; and then remove wedge before is starts to set up, which will return the silicon to the correct shape for your part. 2
TJTX Posted May 18, 2019 Author Posted May 18, 2019 Had to piece it together a bit. This may become my favorite build if I don't screw it up. The drop tanks and prop just adds a neat look to the airframe. 5
Jeff Posted May 18, 2019 Posted May 18, 2019 The drop tanks look really cool, makes the plane 'Look" fast...... I'm really liking this a LOT 1 1
TJTX Posted May 18, 2019 Author Posted May 18, 2019 What do I make the casting block out of? Plastic, putty, etc...? 2
