Daft project or is it? 1/32 Short Stirling III
:)I am thankful to Evergreen actually
Sone more progress by adding detail to the flightdeck, heelboards,
seat mountingrails, the raised floor for the watertank, pencilbox.
And I started adding the stringers to the starboard fuselage half. This is fun.
I may just to that.
Today I have done most of the stringers. The nose still needs to be done but I have to get the drawings to determine the apertures for the noseturret and bombardier transparency first. After the stringers the halves needed to be checked for fit. But that has been completed now. Work is about to start on the details.
6 hours ago, Wingco57 said:
I may just to that.
This all is like manufacturing the aircraft, not modeling! Absolutely stunning work Cees! I love it!
Never satisfied ey Peter?:D
some more work being done. The seats are mounted on seatframes which are quite tricky to make. Using a jig from scrap plastic ensures all frames are identical, these will have to be built up to “H” section and two frames will be joined to form one seat frame.
. Also the control columns have been fitted. The wheels will be done much later after painting and finishing of the cockpit as they will be very fragile.
Simply mindblowing what you are doing...
Isn‘t there any accessories delivered with the kit?
Thanks chaps,
well the seatframes do not actually run on rails but they fit very nicely. Very pleased how this difficult stage has turned out. The X-members were a bit of a problem at first but then I thought of Ikea and in fact it was quite easy with interlocking sections.
2 hours ago, Wingco57 said:
Thanks chaps,
Aircraft factory is open again!
Simple to comment: I‘m speechless! :unworthy:
There are not many forums where a Sunderland and Stirling are underway in 1/32.
In the meantime I have started on the throttle box. The basic shape you can see here.
And some pics showing an actual one restored by the Stirling Project. This throttle box was restored using the recovered one from B Mk III BK716 for reference. BK716 will be the aircraft I am modelling and the wreck of which has been succesfully recovered last September from the ijsselmeer. I have been involved with this project from the start since it was located during 2009.
  • Sad 1
Next session from the aircraft factory!
Awesome progress!
