1:32nd scale Salmson 2-A2
sandbagger
 Share
Hi all,
The tail unit is done.
That includes the rudder and elevator control cables, the twin bracing wires for the fin and the fin and tail plane support struts.
These twin wires, like the flying and landing wires, will need infills and wrapping.
Mike
Mike I learned something new today.  Thank you.
I never once thought that linen effects could be applied over a painted camo surface and the colors would remain relatively unchanged.
I like this because I’ve used various sheets of PC10, PC12 and linen in the past, and had a problem of color change around wingtips when you heat it and pull it taught to conform.
This method looks a bunch better with no chance of losing the pigment on edges.
This Salmson is one of Wingnuts toughest builds, simply because of the way the French built their aircraft with the two wings set so close together. My fat fingers have no chance in there.  Everything’s done with tweezers.
Yes there is very little, if any colour change to the base coat as those decals are clear.
Your problem could be that the edges of the 'Aviattic' decals are overlapped slightly.
If so, the effect is to double the decal thickness and that will cause that area of overlap to darken.
Mike
Hi all,
I've fitted the linen wrapped infills between the pairs of flying, landing and fin bracing wires.
I tried my previous methods of using baking parchment paper and 0.2 mm thick plastic card strips.
However, the length of these pairs of wires are long and they flexed too much.
Therefore, I cut strips of 'Aviattic' CDL decal to 1.75 width of each pair of wires.
The water I used to release the decals was cold, as this tends to release the decal in a more rigid state than warm water would.
That made it easier to position the decal strips onto the wires.
The decals were laid centrally onto the top sides of the wires and left to allow the residual decal adhesive to grip to the wires.
I then applied 'DACO Products' strong setting solution across the top of the decal strip.
As the decal started to soften, I teased the edges under the wires to fully wrap them with the decal.
Not easy but I think it should look OK once I've painted the decals.
This is necessary as the decal is thin and the blue rigging wires shown through.
Then it's onto finishing the rigging (drag and side wires),
Mike
Hi all,
At last the rigging is complete.
I've added the side bracing wires from the fuselage to the underside of the upper wing.
Also the upper and lower drag wires from the engine bearer frame to the underside of the upper wing and leading edge of the lower wings.
The flying, landing and fin bracing wire infills have also been painted with the same colour as the undersides of the wings and fuselage.
I chose CDL as it's difficult to know if these infills were CDL or blue (as for the rigging wires.
My assumption is that blue would has stood out too much against the camouflage surfaces, so I opted for CDL.
So now it's onto the four wireless wires from the cabane struts to the underside of the upper wing.
Also the fuel tank vent pipe,
Mike
Hi all,
I've added the vent pipe from the fuel tank, using 0.4 mm diameter black tube from 'MFH'.
Also the four wireless wires, made from annealed and twisted 0.2 mm diameter copper wire.
Now onto the front end parts,
Mike
Hi all,
I've now added the pilot's Vickers machine gu ('GasPatch replacement), gun sight, ring site, mirror and coolant header tank.
Also the wind driven pump/generator, with pipe from 0.4 mm diameter black tube from 'MFH'.
Just the ailerons and control cables wind screens and observers weapons to add, then it's onto the figures,
Mike
Hi all,
The aileron control cables have been added.
The mono-filament used is 0.08 mm diameter and is left clear.
Although the structural rigging was painted blue, the control cables were left unpainted.
I assume this was due to the cables being regularly adjusted and maintained.
Now onto the observers weapons,
Mike
Hi all,
The observers twin Lewis machine guns assembly is now done.
I replaced the kit supplied weapons with 'GasPatch' weapons.
This required modifying the kit supplied gun mounting and adding both the cross bracing between the gun handles and the spreader bar between the breach blocks.
The gun mount spindle is 0.4 mm diameter tube located through holes drilled in the gun mounting lugs.
The cross bracing is 'EZ' line (heavy) routed through 0.3 mm diameter holes drilled diagonally the the ends of the handles.
The twin bungee lift cords around the gun support tube are also 'EZ' line routed through 0.4 mm diameter holes drilled through both sides of the tube pivots at the base ring.
Just the two windscreens to go and the model itself is complete.
Then it's onto the figures,
Mike
Hi all,
The four figures are now done.
These figures are from 'Copper State Models', although two were German ground crew figures.
I modified one of those heavily as he will be stood in the observers cockpit.
The heads were replaced on both by changing French heads around and using one head from 'Hornet Models'.
The figures were painted using a combination of 'Tamiya' and 'AK Interactive' acrylics.
The model is complete now, apart from the display case and a replacement propeller front hub (wrong type fitted).
Once again, many thanks for your support and encouragement throughout this build.
I will post completed photographs in a week or so,
Mike
Such incredible work, wow!  Congratulations on another stunning build!
I have a few WW kits in the stash, and have been waiting to get a little better with the airbrush before tackling one.  I have to say, I think you've convinced me to go with those Aviattic linen decals.  The textured look is amazing.
  Only 75 emoji are allowed.
 Share
