On 6/7/2025 at 1:38 PM, DocRob said:
I have a different rolling tool since years Paul and I use it regularly. Mine has a rubber backside, which also helps to roll PE parts to shape. Annealing makes  rolling PE parts a lot easier, as it takes the springiness away from the brass. Heat the brass part over a flame, until it turns blueish. Don´t overheat and let the brass glow. Annealing takes away the tension in the kristalline structure of the metal.
I have a similar tool from The Small Shop (I think recently closed up shop) that I use a lot on 1/350 and 1/700 ship models.  Really helps to get curves in PE.  I haven't annealed my PE parts before, but will try it especially with thicker brass (I think 1/700 brass is probably too thin).
Rob is right about the springiness of non-annealed PE.  To deal with it, I usually roll to a thinner diameter to account for the spring.  Good to know that annealing takes away the spring.
Whohooo! Is perhaps understatement😀 I hope you share your build of this magnificent Duck!
Yes  its a understatement.
Will open a topic but first some other things to do.
Mark
A number of items including:
A 1/35 RSO OST  from Miniart.... Had to get this one. Looks tiny and complex. What to expect from Miniart (Manypart)😀
Loads of masking tape from Tamiya
A pliers and metal nipper from Godhand.
A "Tweezer-action" scissors and a Conical file from Tamiya.
From Dspiae a kind of double-ended scraper tool.....They call it a " Broad edge broach".
It has a flat chisel blade on one end and, as shown, a double edge point at the other. This should be useful for eliminating the seams
on the resin figures I have. These are good products, and I hope people find this post useful😀
Paul, I'm happy that you post about the tools you're getting, especially the Dspiae ones as they're usually high quality and useful.
Just had to, but it will be quite a while before I build it, Have to improve my skills a bit first.
Dennis
Just arrived today, my early Father's Day present.
Looks great and has an easier breakdown that the previous version I had.
I kinda stuck on my Badgers Gus been using them only since about 12 yrs old with Propel :hsmack:Everybody raves about the Steiner though.....;)
This is the updated version of my previous airbrush Kevin and it seems to be a step forward in terms of detail. Neat little details on the needle and nozzles so that you can't mix up the different sizes, etc. Just seems like typical German engineering efficiency.
That seems to be the case often with German machining hell I see it in the WWII guns I have every piece just about has a serial number.;)
My turn!
This will be a first for me. Well, several firsts.
1). First time I’ve had the bench already cleared and ready for the new arrival.
2) First printed model I’ve ever built.
3) First model I’ve ever spent this kind of coin on.  I’ve come close if you consider kits + AM.
Not gonna lie.  I’m a little intimidated.  I know nothing about 3D printed parts.  What cleaners can I use before priming?  Instructions mentioned priming before any paint goes on.
CA and epoxy I assume are the only glue options. Maybe some white canopy glue too.  Definitely won’t be cracking open the Tamiya thin cement or my sprue goo this time around.
I think my first task will be cleaning off all the printing supports and priming each part individually before any assembly.
3D-printed is no different than « normal » resin. So, yes, CA, or epoxy glue.
The only plus is that, having been cleaned of unwanted resin left over from the printing process with IPA, you can skip the degreasing step !
Hopefully mine will be there when I come back from my trip to Bali (catching my flight later today).
Looking forward to see your build :popcorn:
Remember when the Plymouth Prowler came out and the talk of heresy when folks found out it had a V-6 instead of a V-8? Imagine the cries of anguish when Boys Coddington showed off the Aluma Coupe powered by a Mitsubishi 4G63 4 banger!!!
Anyways, Testors released a kit of it years ago and Wheels and Wings recently got one in from a collection.
Definitely an interesting kit, the body is split in half lengthwise.
I also picked up an F2G Corsair conversion. An LSP forum member had it for sale and we met up at the LHS for to get it from him.
Finally I can build an F2G in 1/32.
7 hours ago, belugawhaleman said:
Great selection of kits, Ralph 😀   Hope to see your builds!
Thanks I look forward to a winter of fun builds!
Wasn't sure if I'd post this. considering, but, here it is.... I thought somebody might be interested.
I saw this on Andy's site the other day and thought it would be a fun build....
I posted some artillery builds here before..but in 1/35, well, they're tiny. This thing,
will be reasonably big!
It's Das Werk's  new  1/16 German 7.5 cm PaK 40 (mid/late) 2 in 1 ( DW 16020).
It looks pretty good....There's a choice of 3 wheel/tire combos, a turned metal barrel,  ammo, ammo crates, and ammo cases.
There's also, three decal options, and different muzzle brake options.
No figures, however.... but I'm sure there'll be something from aftermarket soon, if not already.
Anyway, as always, I hope someone finds this useful 😀
A good site for pictures......
https://www.net-maquettes.com/pictures/pak-40-walk/
I hope there will be more guns in this scale.
2 hours ago, Clunkmeister said:
I just couldn't resist this, and it's positively brilliant!  It's been a bucket list kit for 25 years
Looks like premium kit.
Very cool. At first, I didn't realize it was 1/32 scale. An interesting subject and in large scale.
Well, I finally got one of the big Spitfire VIII kits. 2 years ago I ordered a couple of the 1/48 Tamiya F-14 kits during Lucky Models' anniversary sale. They sold oou and were never able to get them back in stock for some reason. So I saw the Spitfire in this year's sale, got them to credit me for the F-14s and it arrived today.
Still have a small balance leftover so I'll look into some AM.
