DocRob Posted August 31, 2021 Posted August 31, 2021 1 hour ago, BlrwestSiR said: Rob, those chairs look amazing. Got any plans for them that you could share or where to buy them? Sue would love something like that too. Thanks Carl, I used the following plans, but they are in German. If you have questions about the plans you can PM me. I followed the basic measurements in the description, except, I used threaded rod of 6 mm (M6) stainless steel and drilled the holes in the wood with 8 mm diameter. In all the construction took three days, it's a relatively easy build. Tipps & Tricks: Kentucky Stick Chair (senotto.de) You can buy this kind of foldable chair as well, for example in the Netherlands. Fieldchair | Weltevree - order now, free shipping within EU From this company I bought the sheepskin with a leather loop, to attach the skin to the chair. Cheers Rob 1 1
DocRob Posted August 31, 2021 Posted August 31, 2021 1 hour ago, GusMac said: Very impressive woodworking skills there Rob. At least you've got weather to enjoy them in. Softwood gets destroyed in about a season here Thanks Gus, in the moment we have a great summer, but we have harsh conditions here too, lots of humidity, wind, fog and then everything changes to dry heat, not perfect for softwood as well. I built some Adirondack chairs two years ago from a very durable wood, but I have to rework them this year. The new chairs are foldable and will be stored inside, when the weather turns bad. The new built sea view terrace is more a summer terrace, because there are cruel winds blowing in winter time and we will use the place for a winter barbecue only on days with no more than a breeze with a Kamado barbecue, which distributes a lot of heat. Tha Canary Islands are called the islands of eternal spring only for the tourists, it can be pretty rough here, specially northern bound and up in the mountains. I do feel cold more often here, than I felt in Berlin, where the houses are better insulated and better heated. Cheers Rob 2 1
Bomber_County Posted August 31, 2021 Posted August 31, 2021 Stunning Rob, reminds of the days I used to watch New Yankee Workshop…… 3 1
Peterpools Posted September 1, 2021 Posted September 1, 2021 17 hours ago, DocRob said: Actually it's off the bench right now, because it's ready. Two 1/1 models of Kentucky Stick Chairs, which I built over the last week. Another summer project, which will be a present for my wife's birthday, to use on our new sea view terrace. For colder days, you can put some sheepskins on. Cheers Rob Rob Awesome work and perfect for a summer project. Keep 'em comin Peter 2 1
DocRob Posted September 1, 2021 Posted September 1, 2021 9 minutes ago, Peterpools said: Awesome work and perfect for a summer project. Thanks Peter, these chairs are comfortable and easy to build compared to the Adirondack chairs, I built two years ago. Cheers Rob 2
GusMac Posted September 1, 2021 Posted September 1, 2021 22 hours ago, DocRob said: Thanks Gus, in the moment we have a great summer, but we have harsh conditions here too, lots of humidity, wind, fog and then everything changes to dry heat, not perfect for softwood as well. I built some Adirondack chairs two years ago from a very durable wood, but I have to rework them this year. The new chairs are foldable and will be stored inside, when the weather turns bad. The new built sea view terrace is more a summer terrace, because there are cruel winds blowing in winter time and we will use the place for a winter barbecue only on days with no more than a breeze with a Kamado barbecue, which distributes a lot of heat. Tha Canary Islands are called the islands of eternal spring only for the tourists, it can be pretty rough here, specially northern bound and up in the mountains. I do feel cold more often here, than I felt in Berlin, where the houses are better insulated and better heated. Cheers Rob Sounds like you've got it all planned out Rob. Only been to Gran Canaria of your islands and it was down in the very south (Puerto Rico) in July, so far too hot and humid for me. 🥵 2 2
BlrwestSiR Posted September 2, 2021 Posted September 2, 2021 On 8/31/2021 at 6:06 PM, DocRob said: Thanks Carl, I used the following plans, but they are in German. If you have questions about the plans you can PM me. I followed the basic measurements in the description, except, I used threaded rod of 6 mm (M6) stainless steel and drilled the holes in the wood with 8 mm diameter. In all the construction took three days, it's a relatively easy build. Tipps & Tricks: Kentucky Stick Chair (senotto.de) You can buy this kind of foldable chair as well, for example in the Netherlands. Fieldchair | Weltevree - order now, free shipping within EU From this company I bought the sheepskin with a leather loop, to attach the skin to the chair. Cheers Rob Thanks Rob! Looks like I might have a project for next spring. I was thinking of Muskoka chairs originally (they're like Adirondack chairs but Canadian) but I like that yours are something different. 2
BlrwestSiR Posted September 2, 2021 Posted September 2, 2021 I think I found out why I'd put the Esprit back in the box. Masking the trim and window frames... Now to do the sub version. Carl 6 2
Peterpools Posted September 2, 2021 Posted September 2, 2021 Carl Lots of work but the results are so well worth it. Keep 'em comin Peter 3
DocRob Posted September 2, 2021 Posted September 2, 2021 38 minutes ago, BlrwestSiR said: Thanks Rob! Looks like I might have a project for next spring. I was thinking of Muskoka chairs originally (they're like Adirondack chairs but Canadian) but I like that yours are something different. I had to google the Muskoka chairs, but they are more or less the same like the Adirondaks. These were the ones I built two years ago, definitely more work than the Kentucky Stick chairs. Cheers Rob 9
Bill_S Posted September 3, 2021 Posted September 3, 2021 15 hours ago, DocRob said: I had to google the Muskoka chairs, but they are more or less the same like the Adirondaks. These were the ones I built two years ago, definitely more work than the Kentucky Stick chairs. Cheers Rob Rob, you did a beautiful job on those chairs. I spend a lot of time camping in the Adirondacks; those chairs are common around here. They're surprisingly comfortable. 3 1
Wumm Posted September 4, 2021 Posted September 4, 2021 On 9/3/2021 at 7:03 AM, BlrwestSiR said: Now to do the sub version. Fishing for compliments Carl? I'll get Bach in my box now... S 1 3
smitty44 Posted September 4, 2021 Posted September 4, 2021 It's a long modeling weekend here in the US! What's everyone up too? 3
BlrwestSiR Posted September 4, 2021 Posted September 4, 2021 1 hour ago, smitty44 said: It's a long modeling weekend here in the US! What's everyone up too? The Canadian International Airshow starts in a couple hours so I'm going to take the boys. It's a quick 15min bike ride from our house. Then, I'll see if I can get a bit of bench time. 4
smitty44 Posted September 4, 2021 Posted September 4, 2021 34 minutes ago, BlrwestSiR said: The Canadian International Airshow starts in a couple hours so I'm going to take the boys. It's a quick 15min bike ride from our house. Then, I'll see if I can get a bit of bench time. Awesome! I was wondering if anyone else liked real airplanes. 🤣 I'm going to the Reno Air Races in two weeks! 3
BlrwestSiR Posted September 5, 2021 Posted September 5, 2021 12 hours ago, smitty44 said: Awesome! I was wondering if anyone else liked real airplanes. 🤣 I'm going to the Reno Air Races in two weeks! It was a good show. Started off with a CF-18 solo display as always and ended with the Snowbirds. In between was a C-130, P-51, F-35, Canso, and a aerobatics plane that I don't know. I don't have pics as all I had was my phone. 3
BlrwestSiR Posted September 5, 2021 Posted September 5, 2021 Got the sub Lotus masked off. Some over spray in spots but that part's done. 7
Bill_S Posted September 6, 2021 Posted September 6, 2021 Pulling this one forward. Hopefully it will be ready for my club's show at the end of the month. Ready for an undercoat of RLM 66 prior to priming the nose with Mr. Surfacer 1500. 6
DocRob Posted September 6, 2021 Posted September 6, 2021 On 9/2/2021 at 10:02 PM, BlrwestSiR said: Thanks Rob! Looks like I might have a project for next spring. I was thinking of Muskoka chairs originally (they're like Adirondack chairs but Canadian) but I like that yours are something different. For my Adirondacks I used the following Festool plan. It's in German unfortunately, but the PDF includes a part list and drawings of the parts. Baupläne Holz | Holz-Ideen & passende Bauanleitungen (festool.de) Cheers Rob 3
BlrwestSiR Posted September 7, 2021 Posted September 7, 2021 Wet Nellie is almost finished. The road version is coming along too. 3
Bill_S Posted September 9, 2021 Posted September 9, 2021 Revell He-219. Base color of RLM 76 is done. Now onto that "splotch camouflage. Any have any wisdom on how to do it? 4
smitty44 Posted September 9, 2021 Posted September 9, 2021 1 hour ago, Bill_S said: Revell He-219. Base color of RLM 76 is done. Now onto that "splotch camouflage. Any have any wisdom on how to do it? Thin paint, low air pressure, and something to rest your hand on. 2 1
