I love using those Phil.
In my experience the only thing to watch out for is a dry needle tip, I use a q tip to clean it periodically while i'm spraying.
Expand
Have you tried using both their thinner (retarder in it) and a few drops of flow improver? I found that you get more time between q-tip needle cleanings.
Expand
If you want to avoid a gruesome cleaning session of your airbrush, test mixing with retarding thinner in a jar first. All my tests with Valejo Air and Mr. Leveling thinner went into a tar like lump. The thinner worked with some AK acrylics but there were others which were unusable.
Expand
In this video flow retarder and flow improver are mixed with Alcohol and water for a homebrew thinner. I have got the ingredients, hope to try this weekend.
Kev
Expand
Thanks for the tip.
Vallejo acrylic paint doesn't work with alcohol because it is a true water based acrylic paint, not a lacquer based acrylic paint like tamiya or others. If you use anything other then there thinner or distilled water you will end up with a gooey mess.
 There flow improver and flow retarder work very well. I only use there retarder when brush painting, but there flow improver works great when you add a few drops to your airbrush when spraying.
Ron G
Ron G
Expand
Yes, definitely no alcohol, it makes Vallejo coagulate and you will have hours of fun cleaning your airbrush. If that ever happens, you have no choice but to tear it down. I learned that the hard way with MIG and Ammo by Mig paints, one is alcohol based the other is just like Vallejo. To this day I still forget which is which.
Been extraordinarily busy as of late, but there has been a bit of progress on my bench.  After this I'll be taking a break from big complicated builds and putting together a few Hasegawa kits to remember the fun of just building for fun.
Hi Folks!
Here are some pics of the continuing work on the M1A1HA Abrams with T.U.S.K. I mods.
This is the Loader's Armored Gun Station, (LAGS)
TTFN
Barry
  On 2/14/2020 at 11:48 PM, Barry said:
Thanks Gents,
I try hard to model what I see, it's challenges the "little gray cells"!
Barry
Expand
Do tell, do tell....harv
  On 2/15/2020 at 10:32 AM, Bomber_County said:
Barry, absolutely stunning, please do not tell me this is 1/35, if so wow..........
Expand
Hi Phil,
The model is 1/16 scale and Radio Controlled. I have found that the scale is great for adding even the smallest of details.
Barry
Here  are some pics of the Tank Commander's Cupola and M2 50cal. Mount, The mount is standard fair on the M1A1 with the addition of the Thermal Imager/Sight.
TAFN,
Barry
