Smitty that’s absolutely gorgeous, I’ve got to publish that in LSM completed projects...........please.......
Fine by me
I ammNOT a believer in black basing,  it this model is mostly NMF, so I believe in a black under surface go make the aluminum pop.
So, I was ri eying the top patch and reading list rivets with my trusty RB riveter, when I hear the ominous “Crack” from the bottom of the fuselage.
Yep, cracked a seam, but it’s now fixed.
I am REALLY happy how the Mk.X doublers and Jerry blanking plate came out.  Once riveted, hey really look the part.
I wanted the turret blank to look semi homemade as if it was done by service members in a cold hangar, and it does.
Very happy so far.   Now, mask off the top white area and prime it white.    Then mask off the lower fuselage, mount radar dome and rear vision camera, and paint in in ADF Grey,
She’s coming together.
1 hour ago, smitty44 said:
Better polish that black for a couple hours first
At least a couple hours. 10,000 grit.
2 hours ago, GazzaS said:
Buffing with newsprint is a good way to increase sheen, too.
And I’ve always found the best basic white is often just buffed Tamiya primer.
I'll have to try that as I have a couple bug projects that are white.
+1 !
I'm impressed with the work so far Ernie.
Why is it we all want more photos but you tease us with just one ??
I am so looking forward to seeing the NMF and then the red  . . .  it will be fantastic or even better than that B)
David
Sorry for the lack of pics, folks. the issues I have is that I use my iPhone for a camera and the depth of view is not so good. Plus I'm a hideously bad photographer as well. :)   I'll try to get more pics, especially when it isn't just a black blob on my bench. My camera shows little else as of now.
5 hours ago, Bomber_County said:
Looking good Ernie, are you on track for the Nats?
So far so good, but not if I keep cracking finished seams and having to give up every Saturday for other duties.
On 5/31/2019 at 9:01 PM, smitty44 said:
Threadcreep! I missplace the paddle blade props so pointy ones for now. Kits World decals a little oversized, but I'm happy.
Smitty - do you need the paddle blades?
