1to1scale Posted June 16, 2019 Posted June 16, 2019 This was my second Wingnut kit I started, i started this almost a year and a half ago on “another” forum. This was going to be a mostly OOB build using Master brass barrels for the machine guns and Aviattic Lozenge decals. It started well, bus as I always hate doing decals, the progress “stalled” when I got to the wings with their miles of decals. I am so close to finishing, I figured I would try to finish this up before Chattanooga. My choice of schemes will be the yellow nosed bird. 3
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 December 26, 2017 I had just sprayed the Linen color and applied decals to the fuselage, IP, and floor. That was my first attempt at decal woodgrain instead of painting it. I finally broke out the colors and did a bunch of airbrushing this week. I did not fill any seams in the tanks and boxes, because of the whole fuel tank, only the two filler caps can be seen, and only the feed chutes from the ammo box can be seen with the cockpit buttoned up. 4
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 Dec 27, 2017 It was detail and assembly time for the cockpit. I added control rods and rigging, the rigging was fine ez-line and I used .015 music wire for the throttle and spark advance rods. Next was assembling with a little weathering. Finally this nightmare of tubing for the engine bearers...I never held my breath so long. At one point I broke the lower piece and had to glue tiny tubes back together. 7
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 Dec 31, 2019. Engine is built and painted, with weathering. I added spark leads using gray braided fishing line. 7
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 Jan 14, 2018 I have been working away doing lots of tedious work on this little Fokker, mostly assembling and fitting panels and misc parts, closing up the fuselage, wings, etc. nothing really to take pictures of, yesterday I laid down the initial paint. I have to say that this being an early Wingnut kit, I had a lot more flash and seam lines than the Snipe I built. The fit was also more fiddly, the many panels in the cowl area don't fit perfectly, I had to do a bunch of sanding and trimming. Most of the fit issues i don't think were my own doing, but related to the options on the engine. The front 200hp air pump was not even close, I had to trim the upper cowl corners square, and the rear water valve also contacted the cowls. I went back and double checked the fit of the framing, but everything seemed to be in the right location, so I believe that just having all the separate engine support tubing pieces just led to tolerances stacking up. This kit was definitely not the perfect click fit that the other Wingnut kit I built. However, now that I am past that, I know what to look out for in future builds, and I would have built the font framework in a different order next time. I will have to mask and paint the blue next. Masking the engine and cockpit was challenging, but I ended up finding a way. I left the upper cockpit cowl separate as they were clearly separate pieces on the real aircraft, so no filling was required. I laid down many coats of my custom yellow mix, in all it took about 5-6 coats to finally turn opaque. In hindsight I probably should have primed everything in Stynylrez White first, but having never tried Tamiya yellow over gray before, I didn't know. The color is a custom mix of Tamiya gloss yellow with about 30% flat white mixed in. As a base for the Aviattic Lozenge decals, I spayed a 50/50 mix of Tamiya gloss white and deck tan. This is my mix for linen I used on the Snipe lower wings. 5
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 Jan 20, 2018 I made some time to get the blue down on this littl Fokker. It ended up a little darker than I wanted, but other wise ok. Unfortunately I got some blue overspray on both sides of the cockpit at the bottom, I will have to touch that up. 5
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 Feb 23, 2018 I forced myself to start the Lozenge decals tonight. I have been avoiding these for a month now. Decals are not my friends, but I bit the bullet and figured, I have backup wingnutdecals if I screw this up. In the end, these were not too bad, I trimmed them all up with a knife, then started dipping. I quickly learned not to use decal set, because hey won't slide with it. I'll start the bottom wing tomorrow night, and work the edges with micro sol on the top wing. 5
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 June 16, 2019. So that was where time ran out, wife got a new job opportunity in Nashville, and we started to pack, the little Fokker got packed up and shelved. Since I was fairly close to finishing, I wanted to resurrect this little guy and get it all buttoned up, and take it to Chattanooga. Most of the painting was done, just needed to finish the lozenge decals and slap it all together. Also, a special thanks to Mike (serian01) for getting me the Proper Plane Axial prop for this project! 5
Bomber_County Posted June 16, 2019 Posted June 16, 2019 Stunningly clean build, the cockpit and engine are works of art, yet to start my first WnW hope I can come somewhere close.....Congrats 4
DocRob Posted June 16, 2019 Posted June 16, 2019 Your Fokker looks great, very clean built and the painting looks nice. Can't wait to see you finish her. What type of color do you use for the brass petrol tank? It has very fine grain and that's what I like in metallics. Cheers Rob 3
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 2 hours ago, Bomber_County said: Stunningly clean build, the cockpit and engine are works of art, yet to start my first WnW hope I can come somewhere close.....Congrats Thanks, but i have to give credit to Wingnut. Everything as painted as instructions show, I did zero research other than the instruction book. If you follow the book, it works. 4
1to1scale Posted June 16, 2019 Author Posted June 16, 2019 1 hour ago, DocRob said: Your Fokker looks great, very clean built and the painting looks nice. Can't wait to see you finish her. What type of color do you use for the brass petrol tank? It has very fine grain and that's what I like in metallics. Cheers Rob I’m having trouble remembering, but all the paints were Wingnut recommended Tamiya, the metallics were Vallejo Metal colors. I think the brass was VM gold, but i thought it looked like unpolished brass. 4
GazzaS Posted June 17, 2019 Posted June 17, 2019 Your Fokker looks great! I'm glad you're able to get back to it. I've heard quite a few stories about the Fokker's panels. I have a Fokker from WNW... but haven't touched it yet. I only did my first lozenge job recently. I found it daunting before I actually dove in. Gaz 3
SapperSix Posted June 17, 2019 Posted June 17, 2019 I had never even considered a WWI subject until I came here. Nothing for or against I just never considered it. But work such as this make me want to go out and make a bunch of WNW models. The variation of subject and discipline is sucking me in for the kill. Amazing work! 4
Administrators Clunkmeister Posted June 22, 2019 Administrators Posted June 22, 2019 On 6/16/2019 at 9:36 AM, 1to1scale said: Dec 31, 2019. Engine is built and painted, with weathering. I added spark leads using gray braided fishing line. Time travel! Mark, you’re insanely more talented than I thought! 5
Axeman Posted June 22, 2019 Posted June 22, 2019 Great work. One of these days I need to try a wing nuts kit. I think doing the rigging is holding me back. Doing the antenna’s on WWII aircraft is my week spot. Everything looks great. 4
Jeff Posted June 23, 2019 Posted June 23, 2019 21 hours ago, Axeman said: Great work. One of these days I need to try a wing nuts kit. I think doing the rigging is holding me back. Doing the antenna’s on WWII aircraft is my week spot. Everything looks great. Me TOO ! 2
1to1scale Posted July 3, 2019 Author Posted July 3, 2019 I now have all but the top of the bottom wing decaled, I am actually surprised how close I was to finishing it before it got shelved, one the wings are done, it’s just final assembly. I only need to paint the the guns and tires. 4
1to1scale Posted July 15, 2019 Author Posted July 15, 2019 Decal work continues, got the prop finished, painted a few more tiny parts, and pit together the Master barrels on the Wingnut bodies. Next is some touch up work and and some clear before weathering. 7
Administrators Clunkmeister Posted July 15, 2019 Administrators Posted July 15, 2019 Mark and Tony, you’ll need to give me pointers. I have several of these and have never built one. Or a D.l I keep going back to the aircraft with a massive web of rigging. :/ 2
1to1scale Posted July 15, 2019 Author Posted July 15, 2019 On 7/15/2019 at 9:20 AM, Jeff said: Your decal work is superb........................ Thank you for the compliment, but... No, its not. I hate decals, and the extreme amount of decals means I have quite a few crappy areas. Aviattic decals came out OK on all the top surfaces, but silvered on the bottoms, and the Wingnut decals are about as compliant as the DMV. Once again, these decals are fighting me all the way. I will never do another Lozenge decal plane again! I would do masks before another. I am finishing this, but I don't think its NATS worthy. 1
