RCAF Liberator GR Mk VI
  • 3 months later...
As mentioned, with the Strike Valkyrie finished it's time to get back to the heavies.
First thing up was installing the flight crew's seats.
With that done, time for the canopy.
Hopefully tomorrow I'll have that masked and can start on the painting.
Very nice work, Carl.  I always get hesitant about cockpits.  I have decided that for the entirety of styrene model building history, that the model making companies have been doing us a disservice.  How many fogged, scratched and ruined canopies could have been saved if they had been engineered so that the surfaces to be cemented were 1/4 in or so from the clear area?
anyway…. I look forward to more progress.
Thanks folks! It feels good to have this back in the bench. Well, it never actually left but got piled on at one end.
Anyways, I taped up the openings in the fuselage and used the closed bomb bay doors to cover that section up.
I then got a coat of green down over the window frames and then started priming the fuselage.
I hear you Gary. The Tamiya F-4s are some of the worst for that. And it looks like the GWH P-40 has a similar issue with the rear windows on that kit.
23 hours ago, ThomasProbert said:
You're a brave man putting the canopy on this early in the build - if it were me it would be filled with sanding dust and debris in no time at all :mellow:
Thanks Tom! I'm hoping with everything else sealed up I won't get anything into the fuselage. Plus I've already done all the seam sanding and filling. We'll just have to wait and see I guess
Here's the fuselage with a coat of primer on. I'm using AK Primer which is lacquer based.
For the camo, il going to use Mission Models paint. It covers well but needs a good primer under it to prevent lifting. Unless you like the chipped look.
