GusMac Posted June 2 Share Posted June 2 That's a big beastie! Looks really good in that paint job Carl. 2 1 Quote Link to comment Share on other sites More sharing options...
Peterpools Posted June 2 Share Posted June 2 Carl HUGE comes closer but is still not right. Gigantic is closer. Where are you going to display the B-24? Keep 'em comin Peter 1 1 Quote Link to comment Share on other sites More sharing options...
BlrwestSiR Posted June 2 Author Share Posted June 2 39 minutes ago, Peterpools said: Carl HUGE comes closer but is still not right. Gigantic is closer. Where are you going to display the B-24? Keep 'em comin Peter I'm not sure yet Peter. Sue says not in the living room. I think I'm still going with my plan to empty a shelf and replace it with a hopefully big enough display case. 2 hours ago, GusMac said: That's a big beastie! Looks really good in that paint job Carl. Thanks Gus! Definitely no hiding it. 3 Quote Link to comment Share on other sites More sharing options...
Peterpools Posted June 3 Share Posted June 3 Carl Fingers crossed the plan works out perfectly. 🤞 Keep 'em comin Peter 1 1 Quote Link to comment Share on other sites More sharing options...
BlrwestSiR Posted June 4 Author Share Posted June 4 Time for an update. I started fitting the cowl flaps to the nacelles. The railing edge looks a bit thick so I shaved it down a bit to make it thinner. Before: After: Then I masked off the lower side as needed. I started the camo with the Extra Dark Sea Grey. 7 1 Quote Link to comment Share on other sites More sharing options...
mark31 Posted June 4 Share Posted June 4 Looks better now with the thinner edge Nice done. Mark 3 1 Quote Link to comment Share on other sites More sharing options...
BlrwestSiR Posted June 4 Author Share Posted June 4 (edited) From there, I then masked off the fuselage so I could align the camo scheme between the wing and fuselage. I did a quick outline so that I made the camo aligned. Then I took the wing off and continued on the camo. Here's the finished wing dry fit on the fuselage. Looks to have worked out. The other wing is much easier so that will be next. Edited June 4 by BlrwestSiR Fix pic. 7 1 Quote Link to comment Share on other sites More sharing options...
harv Posted June 4 Share Posted June 4 Awesome dude !....harv 3 1 Quote Link to comment Share on other sites More sharing options...
Peterpools Posted June 4 Share Posted June 4 Carl Amazing progress. Glad you thinned out the cowl flaps - they now look so much better. Nice work on the wing cammo and matching the fuselage and wing pattern - looks perfect. Keep 'em comin Peter i 2 1 Quote Link to comment Share on other sites More sharing options...
BlrwestSiR Posted June 5 Author Share Posted June 5 Wing camo is all done now. I masked off and painted the de-icer boots. Here they are l test fit in place. Here's the wing/fuselage join. No glue yet but the fit is decent. I will most likely leave it alone. 9 Quote Link to comment Share on other sites More sharing options...
GazzaS Posted June 5 Share Posted June 5 Superb! 3 1 Quote Link to comment Share on other sites More sharing options...
DocRob Posted June 5 Share Posted June 5 It's very helpful, that you can spray the wings apart from the fuselage. Your camo looks great. Do you buy your paints in gallons Carl? Cheers Rob 3 1 2 Quote Link to comment Share on other sites More sharing options...
Peterpools Posted June 5 Share Posted June 5 Carl Looking so good and mighty impressive. The wing/fuselage seam looks fine and leaving it as is with removable wings if space becomes an issue and if so the wings can be removed for storage. Keep 'em comin Peter 2 1 Quote Link to comment Share on other sites More sharing options...
BlrwestSiR Posted June 5 Author Share Posted June 5 5 hours ago, GazzaS said: Superb! Thanks Gary! 2 hours ago, DocRob said: It's very helpful, that you can spray the wings apart from the fuselage. Your camo looks great. Do you buy your paints in gallons Carl? Cheers Rob It's definitely helped being able to paint the wings separately. Would you believe I've only used just 1 bottle of white, 1/2 bottle of Extra Dark Sea Grey and 1/2 bottle of the Slate grey? All of it has been straight from the bottle without thinning. My LHS had complained that they don't sell much Mission Models paint as it goes a long way. I believe them now after painting this model. 41 minutes ago, Peterpools said: Carl Looking so good and mighty impressive. The wing/fuselage seam looks fine and leaving it as is with removable wings if space becomes an issue and if so the wings can be removed for storage. Keep 'em comin Peter Thanks Peter, I may just leave them removable until I can find a permanent place to display it. 5 Quote Link to comment Share on other sites More sharing options...
Bomber_County Posted June 5 Share Posted June 5 Carl, stunning camo. Have you decided where to display when finished….. 3 1 Quote Link to comment Share on other sites More sharing options...
HubertB Posted June 5 Share Posted June 5 Not at all a criticism of your work, Carl, as it’s really nice and impressive, but the camouflage separation emphasizes the funky wing root profile of the kit … Hubert 3 1 Quote Link to comment Share on other sites More sharing options...
Martinnfb Posted June 5 Share Posted June 5 Carl, I may be wrong, but it seems that HB molded some kind of winglets at the edge of the engine cowling flaps. Hard to say from the picture, that middle transition should be smooth. 2 1 Quote Link to comment Share on other sites More sharing options...
BlrwestSiR Posted June 6 Author Share Posted June 6 Martin, it sort of does look like a winglet doesn't it? To me, I think they tried to mould that bit with the cowl flaps in the open position rather than closed which is what they supplied. Just one more little (or not) mistake. The engineering of the kit really makes me suspect it was to be offered assembled. 3 Quote Link to comment Share on other sites More sharing options...
Martinnfb Posted June 6 Share Posted June 6 Exactly what crossed my mind as well, like those die cast models. 2 1 Quote Link to comment Share on other sites More sharing options...
BlrwestSiR Posted June 6 Author Share Posted June 6 On 6/5/2022 at 9:03 AM, HubertB said: Not at all a criticism of your work, Carl, as it’s really nice and impressive, but the camouflage separation emphasizes the funky wing root profile of the kit … Hubert The wing shape is off but the work to fix it is beyond what I wanted out of the build. Iain on LSP is working on a fix but it's quite involved and I'm not up to it. 3 1 Quote Link to comment Share on other sites More sharing options...
Kaireckstadt Posted June 10 Share Posted June 10 The improvement of the cowl-flaps really pays off and the camo scheme turns out very nice. With this size it’s essential that you can paint the wings and fuselage separately. Made the same experience when painting my HK Lancaster. 4 1 Quote Link to comment Share on other sites More sharing options...
Martinnfb Posted Tuesday at 02:46 AM Share Posted Tuesday at 02:46 AM Watching closely 5 Quote Link to comment Share on other sites More sharing options...
BlrwestSiR Posted Tuesday at 03:36 AM Author Share Posted Tuesday at 03:36 AM 48 minutes ago, Martinnfb said: Watching closely Don't look too closely or you'll see a lack of progress. I'm stuck on the props as I'm not keen to work on them for some reason. Need to get back to it and get them done...oh look shiny yellow thing. 4 1 Quote Link to comment Share on other sites More sharing options...
Administrators Clunkmeister Posted Tuesday at 05:36 AM Administrators Share Posted Tuesday at 05:36 AM Carl, I’ve been following this here and there and I like it, a lot. I can’t get past that wing/fuselage joint, and like Hubert said, the Atlantic pattern camo sure accentuates it. But, if ya want an RCAF North Atlantic patrol bomber, this is the only scheme they came in, so onward and upward. I’ve been watching Iain’s fix on his, and I may attempt something similar, sort of following his lead. This is the #1 reason I haven’t built one yet, since I’ve been paying close attention to his struggles. But yours is looking oh so flawless so far, and what a recovery from that extra interior space problem you gave the bomb aimer… 🤣 3 1 Quote Link to comment Share on other sites More sharing options...
Peterpools Posted Tuesday at 12:43 PM Share Posted Tuesday at 12:43 PM Carl When the juices flow, it will be time for the props. And yes: 'oh look shiny yellow thing' - looks so cool and tempting. 1 1 Quote Link to comment Share on other sites More sharing options...
