BlrwestSiR Posted January 5, 2023 Author Posted January 5, 2023 16 hours ago, Peterpools said: Carl Unreal .. fantastic work and your PE skills are topflight. Nice plan and it's like having money in the bank just in case but seeing how you are sailing through the PE, you will be removing the kit parts. Thoroughly enjoying your progress and following all the way. I'm just still in the cleanup stages with the Kingfisher as I'm only less then a few work sessions away from finishing he P-40 and then it's an all out assault on my GB entry. Thanks Peter! Can't wait to see you make a proper start on the Kingfisher. It took me a long time to figure out how to get decent results with PE. Mostly it was CA everywhere and badly made folds. Some proper tools really made a difference. 3
BlrwestSiR Posted January 5, 2023 Author Posted January 5, 2023 I mocked up the main cabin real quick with some tape and placed the flying bridge section onto it as a comparison of the kit part to the one I just made as well as check the fit. Stock: AM: The brass one definitely makes a huge improvement. I've also found a couple crew figures so have orders those. 10
Peterpools Posted January 5, 2023 Posted January 5, 2023 Carl Agreed - the flying bridge does look so good and a huge improvement. 3 1
Bomber_County Posted January 5, 2023 Posted January 5, 2023 Carl, this is JohnB speed here, great start……. 4 1
KevinM Posted January 5, 2023 Posted January 5, 2023 That's a Nice fit for AM PE Carl either a testament to your skills or engineering or maybe bother. 5 1
Jackster Posted January 6, 2023 Posted January 6, 2023 Fantastic work Carl, looking very good! Cheers Kev 4 1
CANicoll Posted January 13, 2023 Posted January 13, 2023 Your PE work is terrific Carl, definitely makes a big difference. Chris 4 1
DocRob Posted January 15, 2023 Posted January 15, 2023 Wow Carl, your PE work looks spectacular. With ship builds, heavy loaded with PE, it's a shame sometimes, to cover the nice brass with color. The sheet thickness looks way more realistic. Cheers Rob 6 1
BlrwestSiR Posted January 17, 2023 Author Posted January 17, 2023 Thanks guys! It's definitely the PE set making me look good. They did a great job in the engineering of it. I think there's at least 3 thicknesses of brass sheet that they used never mind the thought into how the folds go and what have you. I was hoping to have the Falcon done by now to focus on the Vosper but no such luck. As it was, I got a delivery from BNA World today with some bits for this build. Still don't know how the Aussies can get a package to me faster than one from 20 km away. I received a sheet of moulded bolt heads as the PE set has you trim them, fold them over after cleaning up the attachment point and then glue them on. Repeat a total of 156 times. The Meng bolts I just slice off and glue in place. Much easier. I hope. Before that though, I had to drill out some holes as they are only partially open. You can see the first one I've done. Huge difference once they're all cleaned up. Now I've started on adding the bolt heads to the frame. Just a few more to go. 15 1
DocRob Posted January 17, 2023 Posted January 17, 2023 Nice Carl, good idea with the bolt heads, noted . Cheers Rob 4 1
Peterpools Posted January 17, 2023 Posted January 17, 2023 Carl Great PE coupled with a talented builder is the correct formula. WOW, those Meng NBW's look amazing and surely saved the day. 3 1
Bomber_County Posted January 17, 2023 Posted January 17, 2023 Trying to find stock of those Nuts & Bolts, they are rarer than unicorn poo………I may just invest in a small 3D printer and then I can print stuff at my leisure….. 5
HubertB Posted January 17, 2023 Posted January 17, 2023 8 hours ago, BlrwestSiR said: […] As it was, I got a delivery from BNA World today with some bits for this build. Still don't know how the Aussies can get a package to me faster than one from 20 km away. […] And cheaper for European items shipped to Europe than the European sellers … Hubert 4
Peterpools Posted January 17, 2023 Posted January 17, 2023 NBW's. Try Tichy Trains - model railroading has all such detail items for years. 4
BlrwestSiR Posted January 17, 2023 Author Posted January 17, 2023 4 hours ago, Bomber_County said: Trying to find stock of those Nuts & Bolts, they are rarer than unicorn poo………I may just invest in a small 3D printer and then I can print stuff at my leisure….. Phil, that's why I ordered them from BNA. Not only did they have them in stock, their shipping was cheaper too. 3
Peterpools Posted January 18, 2023 Posted January 18, 2023 I've ordered from BNA in the past and their pricing, service and shipping is excellent. 2
BlrwestSiR Posted January 18, 2023 Author Posted January 18, 2023 Peter, BNA really are great to deal with. Having gotten the hang of adding the bolt heads, the other side went much faster. I then started adding the smaller bolts that go on some of the tube flanges. Griffon give you a template so you space them out correctly. Again, I'm subbing in Meng plastic ones instead of the PE versions. 9
Peterpools Posted January 18, 2023 Posted January 18, 2023 Carl WOW, those NBW's look fantastic - awesome work. Going to start stocking up on those type of details. 2 1
BlrwestSiR Posted January 18, 2023 Author Posted January 18, 2023 Thanks Peter. I just finished adding all the bolts to the first torpedo tubes. Here it is compared to the second one which I haven't started on yet. Now to add the PE details to it. 9 1
Peterpools Posted January 18, 2023 Posted January 18, 2023 Carl A world of difference - the torpedo tube you added the NBW's to looks fantastic and so well detailed. The one you haven't started on yet is now so plain Jane. 3 1
mark31 Posted January 19, 2023 Posted January 19, 2023 Great work with the bolts much better. Mark 4 1
DocRob Posted January 19, 2023 Posted January 19, 2023 Never would have imagined the difference, Carl. I have to order some of these bolts. Cheers Rob 5 1
Jeff Posted January 19, 2023 Posted January 19, 2023 Those Meng bolts are excellent, I have used them a lot on my truck builds, makes a world of difference.... super nice precise job, Carl... a pleasure to watch.... 2 1
