  Ok I'm back. Did a little work on the landing gear and wheel wells. I really like working on this Beaufighter, but there is an inherent problem with doing twin engine aircraft and that is everything has to be done twice, by that I mean two complex wheel wells, two engines and more interior equipment. This in its self is not hard if you don't have to do much scratch building.
   This 1/32 Bristol Beaufighter has virtually no detail to it. Decent engines, but they are lacking a lot of stuff that is visible through the cowl opening. Absolute toy like wheel wells. The landing gear is not very strong (I'm hoping they will be alright, but I'm not that confident). There is alot of scratch building needed to bring this up to par, which I actually like, just ha0rder having to do it twice. Ok enough of me whinning! Here are some pictures for you to look at.
20200404_151210.jpgview of landing gear struts temporarily installed with the scratch built extend/retract cylinder in place.
20200404_151724.jpgsame view with the wheel/tire temporarily installed.
20200404_151929.jpgview of scratch built extend/retract cylinder. I made this from some 1/8" dia. Plastic tube, pieces of the kit part and a piece of 1mm dia. Albion aluminum tube. The two end mounting brackets are made from plastic card stock.
20200404_151955.jpgview of braceing strips added to the wheel well.
20200404_154343.jpgview of the landing gear, with it's support struts and extend/retract cylinder temporarily installed.
20200404_154315.jpganother view of the landing gear.
20200404_161841.jpgview of the port wheel well with the inner fuel vent pipe installed. I have to make the other side vent pipe, plus do the same thing for the starboard side wheel well. There are pipes and wires to be added, but thankfully there isn't much in the Beaufighter wheel wells. Thats it for now be back with more soon.
Ron G
My goodness theres a bucketload of work going into this!! ... Good Job!! ..
I doubt i'd be able to manufacture something like this ... so unless a LOT of additional AM is produced I think I'm still on the wait list for a more modern kit rendition.
Rog :)
Hey all, just a small update.
I think I have the wheel wells done, mostly.
20200405_170636.jpgyou can see the fuel vent pipes in the rear of  both wells. It was tricky making four of them from scratch and getting them all the same. :hsmack::blink::D On the right you can see at the back of the well what looks like two oblong holes, the one on the right is wrong and needs to be filled in. The one on the left is were it is supposed to be.:wallbash::X::hsmack:
20200405_170655.jpganother view looking forward into the wells, There is a pipe that you can see that I drew on tge floor of the wells that needs to be added still, plus a few other bits and bobs.
Ron G
WOW!  thanks guys it's much appreciated. I spent today getting the fuselage insides smoothed out and ready for adding some inner rib structure, also I started on the rear floor, I hade to make this a couple of times trying to get it to fit to the fuselage sides. It will be attached to the port fuselage side, but will fit up to the starboard side when assembled, I hope:rolleyes::wacko:. No pictures yet, I'll try to have some tomorrow.
Ron G
Bloody brilliant!
I love builds where folks just accept a a kit is a canvas to embellish and crack on - this is a perfect example and so well executed
On 4/5/2020 at 2:13 PM, CrankyCrafstman said:
Thanks guys, it's kinda a labor of love...lol:rolleyes:
Ron G
and your labours are loved too :)
Hey all
 Ok I think I have the rear floor figured out, I still have to cutout the observer/gunner's escape hatch. Right now I'm in the process of getting the side wall ribbbing figured out and put in. I have pictures of other builds that did this, plus pictures of the real planes inner side walls. So here are some pictures for you to look at.
20200408_142752.jpgview of port side of the fuselage showing the floor support ribs I scratch built.
20200408_142733.jpgview of starboard side of the fuselage.
20200408_142718.jpgview of the floor, with the rear hatch shown drawn on.
20200408_142701.jpgview showing the floor sitting in place on the support ribs.
20200408_142844.jpgview of the floor from underneath.
20200408_143120.jpgview looking through the pilots opening at the floor in place. Right know all this has had a coat of Perfect Plastic Putty put on and after it dries I will sand it down smooth in preperation for the ribs. That's it for now.
Ron G
OH! I almost forgot. I took some pictures of the Model Monkey rear dihedral tail planes in place on the model and the fit is perfect just some minor sanding around the fillet area to blend everything together.
20200408_152350.jpgstarboard tail plane.
20200408_152329.jpgview showing the 12.5° dihedral on the tail planes.
20200408_152259.jpgview looking down on the starboard tail plane.
20200408_152229.jpgview looking up at the bottom of the starboard tail plane. And yes that's a piece of tape holding the elevator on. Well that's it, I'll see you all in a little while with some more progress.
Ron G
