Chaps, although I enjoy reading this topic it annoys me to read everytime that HK dropped the ball here and there. As a modeller it's a personal challenge to build a model you like and improve what you can.
Accept a kit's faults and enjoy the process. There is no perfection. Deal with it:)
Well its a fine sunny morning in my part of England, no snow as seen in other parts  . . .
Having rubber down the fuselage windows I thought I would spray some primer onto see if there are any flaws
:omg:   :omg:    :omg:
A gust of wind blew it from the shelf . . . . :help:
  • Sad 9
:X: THAT sucks !  What were the chances of that happening..??...... damn, I hope you can repair or replace...... I feel really bad for you....
You are right and it’s fun and modeling to face the challenges of a kit.
What makes me angry is that you pay 350€ (!) for a kit with so many faults and shortcomings.
Guest krow113
Ouch!
Thats a nasty break.
Sand off that strip on the bottom and replace it with plastic card for strength.
19 minutes ago, BlrwestSiR said:
Ian, do you have the clear fuselage you could substitute? If not, let me know as both my kits have one.
I do have all the clear parts but as you know, there is no external detail . . . .
Thanks chaps for your replies :secret:
Give it a couple of days and I will have to resolve the issue one way or another  . . .
Ian
That's horrible, but looks fixable, just walk away for a while and come back to it after a bit of thought, don't rush it.
Dennis
Your so right Dennis,
I will take a day or two to consider the best way to attack it  . . .
cheers
Ian
14 hours ago, FME erk said:
You're right, I forgot about that.
I have made a start on the repair of the fuselage . . .
I took measurements from the opposite side of the fuselage of the oblong shapes in certain positions, hence the numbers. They are just shown in place, fortunate the break is as clean as a flat edge rather than in splinters. I shall initially used Tamiya thin and apply only on the inside face and squeeze together. I shall be taping the two fuselage halves together to ensure that both faces are flush and I dont end up with a slightly bent repaired half  . . ..
Those oblong shapes where there isnt a tab I shall apply HK Sprue glue via the bomb-bay opening and thro' the mid-upper turret aperture.
Here's hoping  . . . :unsure:
Ian
Ian
Sounds like a reasonable plan!
This will for sure be successful, Ian!
29 minutes ago, BlrwestSiR said:
Looks like it's working out. After some sanding and re- scribing it'll look good as new.
Nice recovery there Ian.
That’s really good work, Ian! Will be completely hidden after rework.
Please send me the assistants you had for your work. They seem to be very competent :D...
  • Haha 3
Its been around 48hrs since the fuselage was glued . . .
I have sanded off the excess that was ousing out and found a couple of 'holes' that I have now filled with HK Sprue glue. I think its going to turn out OK :)
More to come in a few days
Ian
Using the sprue glue, it's hard to tell where the crack was since it's the same colour as the plastic. Which I guess means the fix is going well.
I did some work with home made sprue goo a couple years ago.  A week after I used it, I sanded the area smooth and continued with the build.
Then, I applied the primer.  Much to my horror, everywhere that I had used sprue goo, the plastic had continued to shrink after I had sanded it smooth, leaving shallow ditches.  Hopefully the stuff you used stabilized quicker than mine.
  • Sad 1
