Just read though this thread. Amazing work on that PE. I’d have gone cross-yed trying to get it together.
Well done Jeroen :thumbsup2:
Working on small exterior details now. I’d rather put them on after the camo painting but it will be hard to blend them in afterwards. Also bought the vac form canopy so i can cut and use the roof windows that will be posed open.
0565EBD2-3704-4320-B96C-4F73E3604C09.jpeg9A872FE8-217B-4E3A-895C-3B0BC30B00B1.jpeg2F2E9C5D-EEAD-4FA2-9362-ECC363D43060.jpeg
30 minutes ago, Grunhertz said:
Looks great just don't knock those bits off
I was gonna say the same thing ! Like the looks of this so far Jeroen.......Harv. :popcorn:
I do like the Maketar masks although the roundels can be fiddly. Those are fairly simple ones though so hopefully all will be well.
17 hours ago, JeroenPeters said:
Masks arrived!
cut by Maketar:
Maketar masks are just great. Having them used several times, the only thing I noticed is, that in order to get the contours sharp and bubble free, you have to 'rub' them on and they stick very good. If you haven't properly primed or use fragile colours, I recommend to 'detack' them a little on the back of your hand, except you have hairy Werwolf like paws :D.
Working on the engines. I noticed that the mkX has a double inlet tube on the front of the exhaust shroud. These tubes were for cockpit heating. I removed the blunt single Trumpeter stump and drilled out 2 holes. I then cut 4 aluminium tubes and glued them in.
Jeroen
Thumbs up on the canopy masking - so nicely done. A big thumbs up on the cockpit heating inlet tubes on the cowling - it’s those small details that add up in a bug way.
Keep ‘em comin
17 minutes ago, Bomber_County said:
It’s the small things.......looking awesome.......we will see it at Telford?
No, I don't think so. BUT... you will see me and I'll treat you to a pint, which is almost as good :)
On 9/22/2018 at 7:09 AM, Peterpools said:
Jeroen
Keep ‘em comin
Agreed Peter. (What kind of bug? :D)
