HubertB Posted September 16, 2018 Posted September 16, 2018 Peter, of Airscale, did some PE « rivetting rulers », useful for various scales. You might try to contact him and see whether he still has some available. Great job on this Mossie. Hubert 3
PeteF Posted September 16, 2018 Author Posted September 16, 2018 Scratch building parts has its challenges. The Mossy has more of the same part in each nacelle than "mirrored" parts. I keep screwing up left and right. Made progress with the wheel wells. Note the retract piston is on the same side of each nacelle. 4
PeteF Posted September 17, 2018 Author Posted September 17, 2018 Test fitting the most fiddly landing gear ever. There are still 4 additional parts! 6
Wingco57 Posted September 17, 2018 Posted September 17, 2018 11 hours ago, PeteF said: Scratch building parts has its challenges. The Mossy has more of the same part in each nacelle than "mirrored" parts. I keep screwing up left and right. Made progress with the wheel wells. Note the retract piston is on the same side of each nacelle. That's what the real Mossie had too. The undercarriage legs are not handed and one set of tooling can be used to make a complete set of undercarriage legs. Very nice work on those nacelles. Cheers Cees 3
Peterpools Posted September 17, 2018 Posted September 17, 2018 Pete Mighty nice work on the gear . Complicated doesn’t come close Keep ‘em comin Peter 1
PeteF Posted September 17, 2018 Author Posted September 17, 2018 Finished the landing gear (other than adding the brake tube to the wheels and the gear door guards). Fiddly...even knowing it was fiddly it was a 2 day grind to get it all right. Had issues with the resin wheels/tires with paint lifting even though I'd primered them so had to fix that with a brush and had to sleeve the axles to fit the wheels...lots of scratch built detail that was missing from the wheel wells. Broke parts that had to be fixed in-situ...yeah this would never have lasted as all-plastic gear. Pretty satisfying to have it done though. Have to finish one of the engines then can put the nacelles together. 8
PeteF Posted September 17, 2018 Author Posted September 17, 2018 Couple more shots. Muddy fenders, extended stencil decals from Barracuda and double the trouble. 6
Members Mikester Posted September 18, 2018 Members Posted September 18, 2018 Wow! Words escape me, so just wow! 1
Jeff Posted September 18, 2018 Posted September 18, 2018 Looking, rather Spot On, I'd say, nice job, look s real...... I'm liking this a lot.... 1
DocRob Posted September 18, 2018 Posted September 18, 2018 Great result, shame, that all the fine work will be partly hidden in the nacelles. Cheers Rob 2
PeteF Posted September 19, 2018 Author Posted September 19, 2018 12 hours ago, DocRob said: Great result, shame, that all the fine work will be partly hidden in the nacelles. Cheers Rob So much of the detail in this plane is on the bottom that I’m going to display it on a mirror. 3
PeteF Posted September 19, 2018 Author Posted September 19, 2018 Had to scratch build the exhaust shrouds. Thinking about this plane, the exhaust stacks were well shrouded so wouldn't have rusted as much as, say, a Spitfire so I went for heat colors. 2
PeteF Posted September 19, 2018 Author Posted September 19, 2018 Test fit with and without the shroud. 5
PeteF Posted September 19, 2018 Author Posted September 19, 2018 Finally some bits that are starting to resemble an aircraft. 4
Uncarina Posted September 21, 2018 Posted September 21, 2018 Beautiful work Pete! Very impressive. Cheers, Tom
Administrators Clunkmeister Posted September 21, 2018 Administrators Posted September 21, 2018 Speechless! Almost. A clinic is being conducted here. Amazing work, sir. Just amazing.
PeteF Posted September 21, 2018 Author Posted September 21, 2018 Thanks for the kind words. Actually I'm finding that I'm struggling with the same issue I used to have with modeling which is the basic assembly. I'm using too much glue, having trouble filling and leveling the seams and breaking parts that don't naturally end up where they should be. I find that the intermediate years have taught me a lot about painting and detailing and have given me a much greater subject matter understanding (which makes it easier to interpret photos and diagrams into actual parts) but I still can't seem to do basic things like cut a piece of styrene pipe straight or make a little "box" that is symmetrical. There seems to be a finite "resolution" to how fiddly of things I can accurately make. I'd be hopeless in 1/48 scale LOL. 2
Martinnfb Posted September 21, 2018 Posted September 21, 2018 Nice job Pete, not sure if this can be of any help, For rivets Ive been using standard jewellers beading tool. It comes in many sizes. https://www.ebay.ca/itm/23Pc-Handmade-Setting-Beading-Grain-Jewelry-Tool-Diamond-Stone-Beader-Set-Graver/401503836828?epid=9002917188&hash=item5d7b7e5a9c:g:myQAAOSwwvZZOmlA 3
