Few weeks ago I ordered a barrel for my T-34 number183 factory. It arrived on Friday. Since the kit is almost done I had to get me the Zvezda kit, yesterday.
Basic assembly is almost done. I have to say Zvezda‘s new mold is better then Academy, not by far, but better  .image.thumb.jpg.830e7df69444e5dc13a618738866fceb.jpg
Nice pair of Russkies.
Here is that huge inter cooler assembly.
48413360412_ebe51c2cfb_h.jpgP-47 by The 3rd Placer, on Flickr
Fit was pretty good, but I did add strip to the rear of the assembly to tighten it up to the air exit port.
48413360137_095cda4c48_h.jpgP-47 by The 3rd Placer, on Flickr
I also added a chunk of plastic to center the port in the opening.
48413360322_8cb42de87f_h.jpgP-47 by The 3rd Placer, on Flickr
And added strip to the spine to tighten the joint up....
48413212346_f71a727c7d_h.jpgP-47 by The 3rd Placer, on Flickr
If you don't follow the directions and and attach the spine insert to each half instead of as a drop in unit it really fits well.
48413212476_3682e994f7_h.jpgP-47 by The 3rd Placer, on Flickr
Looking good Martin, come to think about it, I’ve ever built one Russian tank, a JS2.............
Looking good Ryan.
Was gonna post about fitting the spine inserts to the fuselage halves but you've beaten me to it. Doing it as per the instructions is just a shitshow.
Yes agreed, my experience with fitting these types of inserts seems to be far better at an earlier stage when the 2 fuse halves are apart.
The IP panel is also interesting, yes it is clear and you are to place a acetate sheet with dials behind it, but there is molded relief on the faces of the glazing spoiling the optical clarity.
I'll get some pics up, but looks like it wont fit my painting style and I will likely modify and paint over it.
I'm hoping to get three IJN fighters on the table for my local show in September. In addition to the Rex I posted previously, here's the venerable Revell mid-wing George. Scratch built cockpit, recasts of the Hasegawa N1K2 wheel bays and eventually Model Master cannon barrels. Complete rescribe of the beast, too.
And the Z-M Shinden...
Ryan, can’t remember is this Trumpeter jug.........looking good......
Yep sorry this is Trumpeter.
Prolly should do a WIP, but I'm terrible at those.
1/16 M1A1HA Abrams with T.U.S.K. I fit. This has been on my bench since Jan 2016. :)
Mantel mounted 50 cal. this is the Counter Sniper-Anti Material Mount.
Barry
Thanks guys!
I have a ton more pics and I had considered starting a build but figured I would wait until I started finalizing things like the 50cal.
Barry
Here's the tank I'm modeling.
Image posted under the Fair Use Act for the purpose of illustration.
I need to clear the [expletive deleted] Picket Boat off the bench so I can get a running start on the next project.  I’ve had some of these waiting so long that the spiders living in the boxes have had time to evolve into entirely new species...!
That pile of ModelSpace boxes on the floor?  That’s 24 out of 25 shipments of the ModelSpace Millennium Falcon...  the last box should arrive this week...  and i’ve already squirreled away a boatload of aftermarket mods to make it even more fun... whenever I get to it! :construction:
Glad to see some other nut paid for the Deag Falcon! If you need the 100a correction kit, let me know I have 2.
