3 hours ago, GusMac said:
Hi Carl, no it's the 1/24 Airfix one. Actually pretty big, about the same wingspan as the 1/32 F15.
Even cooler. I missed out on the bubble top when it first came out and bow all I can find are the car door versions. Probably for the better since it's such a big kit as you mentioned.
Got the nose cone test fit and got a bit of painting on the cockpit.   Lesson learned on measuring 5 times before cutting plastic to add resin.  That's why the evergreen strip is on the nose!  That'll be it for about 2 weeks.  I hope to accomplish quite a bit on my days off in Feburary.
On 12/27/2020 at 4:28 PM, BlrwestSiR said:
Ok, the area around my work bench was getting a bit out of hand. Way too many kits puked up not on shelves and I was just waiting for an avalanche of plastic to happen. So I reorganized my shelf space, got things better sorted and it's much better.
In doing so, I managed to get all my Tamiya single engine prop kits into a single pile:
They e all found a shelf to sit on now. And more importantly, I have some floor space back for the cats and dogs. :D
Carl, that top pic is how I envision John's stash.   NICE STASH!
Tony, I learned the "assemble the basic airframe and make all corrections ahead of time" trick from you.  Doing the same thing on my Thud.  It's one seriously HUGE model.
17 hours ago, Bomber_County said:
I know what you mean my KGV is now 6 years in progress..........
There's only two things I've done for more than 6 years.  My marriage and my job.  I'm not sure which shits me more.
  • Haha 5
Feeling pretty smug about an experiment I just ran with my EPAX 3D printer. I taxed its capacities to the limit, but it worked, with an incredibly smooth surface. The fin tip is broken because of my clumsy attempt to straighten it, but that’s a nothing. One area on the fuse got pretty thin, but I think it’s more to do with my design.
And finally the transparent blue color is just the resin I had available. Some grey one is on its way.
That means I can resume a stalled project that was sitting on my (virtual, as it was in the computer only) SOD ...
I've got a Tamiya McLaren MP4/6 I started in 1993 that I work on once in a while...
Glad I’m not the only one, saying that I have the original boxing of the Airfix 1/24 P51D that I bought in 1974.........it’s started........it’s in the garage...........
I can sympathise with you Gaz...
This sounds like my work and domestic experience about a decade ago.
One place worked me increasingly harder year upon year, as I constantly struggled away out of some misplaced sense of duty. While the other, I was just expecting to get scr#wed on a daily basis.
What a pity I got the two completely mixed up.
S
Enlighten me, Hubert. Why are many of the 3D printed parts designed at an angle?
3D printers all work in the same way: they add layer after layer of the part being printed. When you have straight lines on this part, either vertical or horizontal ones, the risk is great to have visible steps between layers, if the printer is not perfectly laid flat, or if it "wobbles" by the tiniest fraction of a mm on the Z (vertical) axis.
Setting the part at an angle is a way to avoid steps and having the layers more visible as the human eye unconsciously sees "lines" along the part's main axes and spot discrepancies along these.
We have the same approach when tensioning silk screens: if the weft and wave of the fabric are set at right angles to the screen frame, you end up with a moire effect of the straight lines being printed, sometimes to the point that the fine straight lines look wavy. Hence the fabrics are most of the time set on the screen frames at a 22.5° angle.
It is also a way, when you have an overhang of the layer being printed above the one under it, to avoid having to add too many supports for this overhang. The layer is "connected" to the layer underneath by the angle of the part.
Finally, for this part, this was also a way to have the part fit within the limited dimensions of my printer.
By the way, the parts are designed along "normal" X,Y,Z axes. You set them at an angle on the slicing software that preprocesses the part to be printed into the hundreds of successive layers (in the case of the Mystery Ship fuselage, there are about 2900 layers). This is also when you add the supports. This is an art in itself, even though the software does the support design and placement automatically most of the time. I had the supports wrong on the left fuselage half, and stopped the printing about halfway, with an undeterminate "blob" :banned:. A printing for a part this size on my DLP printer takes about 13 hours, for your information.
I hope that my explanations are clear. If not, just ask.
And some printed parts; just fresh of the curing station, and not even fully cleaned up of the supports' tabs. The cowling is VERY thin, about 0.7 mm. Some minor issues here and there, but nothing that can't be solved with a file and some putty or Mr Surfacer.
Great explanation Hubert thanks.
Hadn't even thought of what grain there is in silk being enough to cause moire patterns. Brings back bad memories of physics lab experiments 30+ years ago!
Those guys look great, Kstadt!
From me...  more warship.  The Artwox deck gives a splash of color to the seas of gray.  I'll probably tone it down with a wash later.
What's with the red arrow, you ask?  The ship is crooked.  The red arrow denotes the curved line where I separated the the fo'c'sle  from the battery deck.  Otherwise, getting a decent fit would be improbable.
I don;t know if the crookedness is my fault, or the kit's.  Either way, I didn't want to have to suffer the consequences of having the battery deck fully installed and then have to fill and sand places on the fo'c'sle.
I also began to rig the torpedo net system.  If you get to see close-ups of warship with torpedo nets, you'll see it's quite busy between the torpedo net shelf and the waterline.
...but you'd need the patience of a saint to try to get everything there in this scale.  For the rigging, Uschi line sold under license by MiG Ammo.
It’s a long time since the silk in so-called silk-screens has been replaced by nylon or polyester, but the moire problem still shows up, believe me ;)
This said, moire effects in silk fabrics were sometimes sought after, and amplified by minute variations of the silk filament diameter.
Thanks Gaz,
Which ship is it? Looks great and also as if a lot of work is required to get it right.
I only have one ship in my stash: Revell 1/350 Bismarck...
