seiran01 Posted June 26, 2019 Posted June 26, 2019 Have you tried hitting it hard with a hair dryer or heat gun? 4
smitty44 Posted June 26, 2019 Posted June 26, 2019 Herr Clunk is trying to play it like he was joking with us about the Apoxie Sculpt ,,,,,,, NOT!!! 3
Bill_S Posted June 26, 2019 Posted June 26, 2019 Think of ordering Chinese. One from column A and one from column B... 4
Ryan Posted June 26, 2019 Posted June 26, 2019 The first thing to go is the hair, uhh IÂ mean mind. Ryan 4
Ryan Posted June 26, 2019 Posted June 26, 2019 Clunk is a true modeler, he doesn't need directions......  Reporting the Nats for my ass beating Ernie. 4
Administrators Clunkmeister Posted June 26, 2019 Author Administrators Posted June 26, 2019 Hook, Line, and Sinker.  I LOVE IT!!! 4
harv Posted June 26, 2019 Posted June 26, 2019 Not fooling me cupcake. Admit it, you blew this one........harv 5
FME erk Posted June 26, 2019 Posted June 26, 2019 I'm sure most of us have had a 'senior' moment  . . . It happens to the best of us David 5
Martinnfb Posted June 26, 2019 Posted June 26, 2019 You have to measure and compare the length of your legs Harvey. One is longer. 2
HubertB Posted June 27, 2019 Posted June 27, 2019 48 minutes ago, harv said: So. Everyone knows that...... Harv But the other one’s got bells on it ... Hubert 3
Administrators Clunkmeister Posted June 27, 2019 Author Administrators Posted June 27, 2019 1 hour ago, HubertB said: But the other one’s got bells on it ... Hubert 2
Jeff Posted June 27, 2019 Posted June 27, 2019 You guys rock..................this is so good...... 2
Administrators Clunkmeister Posted June 27, 2019 Author Administrators Posted June 27, 2019 Put on some Voodoo grey last night. MM enamel takes forever to dry, so we’ll give it a few days.  Then, a white top, blue-Black anti glare panel, then paint the orange and blue bands. In the meantime and in between time, I’ll whip up the tailgeathers and get some paint on them.  This is THE kit for cool postwar versions   9
BlrwestSiR Posted June 27, 2019 Posted June 27, 2019 Really nice there Ernie. Have you ever tried using Japan Dryer in your enamel paints? It's a catalyst that speeds up the drying time to a couple hours versus days. I used it on the few times I had to spray MM enamel. 4
Bill_S Posted June 27, 2019 Posted June 27, 2019 Mix that MM enamel with Mr. Color thinner - it will vastly improve drying time! 5
Administrators Clunkmeister Posted June 27, 2019 Author Administrators Posted June 27, 2019 1 hour ago, BlrwestSiR said: Really nice there Ernie. Have you ever tried using Japan Dryer in your enamel paints? It's a catalyst that speeds up the drying time to a couple hours versus days. I used it on the few times I had to spray MM enamel. I use it on oils, Carl. Never tried on enamel, but I will next time. 52 minutes ago, Bill_S said: Mix that MM enamel with Mr. Color thinner - it will vastly improve drying time! Yup, I sure did, Bill. Up till I tried MMP, I used it on everything. The last MM enamel I sprayed was way back when Moby Dick was a minnow, and it finally dried last month. 7
sluggo Posted June 28, 2019 Posted June 28, 2019 7 hours ago, Clunkmeister said: The last MM enamel I sprayed was way back when Moby Dick was a minnow, and it finally dried last month. Are you spraying MM gloss enamel? 3
